P1171 IMMISSION SYSTEM REQUIED
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
asadjatala
Post by asadjatala »
S60 T5 TRUBO AUTO 2001 UK MODEL 93000 MILES
IMMISSION SYSTEM SERVICE REQUIED MASSAGE DISPLAED AND ENIGE LIGH IS ON ASWELL. SINCE THIS MASSAGE I S CAME ON GEAR CHANGES IS DIFFERENT.AS IN IT WOULDN
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Not a specif manufacturer's code. It is a fiuel trim code which can appear if you have some vacuum hose leaks or your MAF sensor is going bad (worst case, you 02 sensor). Check for leaks in your hoses under your hood and clean your MAF sensor. Most any auto parts store can then reset your code for you.
asadjatala
THNAKS FOR THAT WHEN WE CHECKED ON CODE READER IT WAS ON P1171 MANUFACTURER PSECIF CODE YES I HAVE CLEANED IT MAF SENSOR AND TO RESET I TOOK MAIN BATTERY WIRE OUT FOR MORE THAN 10 MINS AND PUT IT BACK ON THAT MASSAGE IS GONE AND CAR IS LOT BATTER BUT ITS NOT GOOD AS ITS SHOULD BE .ITS REV HIGH GIVE YOU BIT OF JERK WHEN GEARING UP OR DOWN . AND I HAVE GAIN A GOOD CLEAN TO MAF SENSOR .IS THERE ANY ORTHER SENSOR I SHOULD CLEAN . AND TO RESET WAS THAT WIRGHT WAY TO TAKE BATTERY WIRE OUT FOR 10 MINS OR HAS TO BE WITH THE COMPTURE TO RESET .PLEASE HELP ME TO SORT IT OUT THANKS
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Stop YELLING with the ALL CAPS and some English please
asadjatala
Sorry for that and its in English if you can read it .if you cannt then learn English and then answer it .dont worry i am not in rush .but sorry for that
THANKS
asadjatala
still waiting for some body to help me out thanks
THANKS
Let me suggest (as I did before) that you look for vacuum leaks. Spray some brake cleaner or carb cleaner or any other flammable spray under the hood while you are idling. If and when it surges, you'll know where the leak is.
asadjatala
thanks i will try this and i will let you know .thanks very much for help
THANKS
asadjatala
hi there is no leak .and problem is still there.any body can help
THANKS
asadjatala
hi is there any body can help please
THANKS
