850R ecu in Turbo model?
This topic is in the MVS Volvo Repair Database » Using an R ECU in a Turbo
andrewrwc
Post by andrewrwc »
What, if any, improvements in power would you see if you installed an 850R ecu into an 850 turbo model.. Would this increase the boost to 850R psi as well as fuel compensation? Just curious as to what would I expect if I installed a 96 850R ecu into my 95 turbo... Thanks!
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Not sure what will happen. You might set some trouble codes if all of the "devices" in your car don't match up with those from the ECU. Maybe others would have a better answer for you.
andrewrwc
Post by andrewrwc »
For anyone interested, I installed my recently acquired used 850r ecu today. Absolutely no error codes whatsoever and it increased the boost from 9 to 14psi instantly. I have not had this car very long so I dont know what else could be attributing to it but that was an easy, cheap plug and play increase in power. Who knows, the car may not start tomorrow but it worked today flawlessly!
Good to know...keep us abreast of how the car runs as time goes on.
code-man850
Year and Model: 855T '96
Post by code-man850 »
Is there any follow up on how your car turned out? I'll be plugging my R ecu into my Turbo this afternoon so I'll be reporting the results too. The only thing I looked out for was the year ranges of the 850 (i.e. keep 1994 & 1995's together and 1996 & 1997's together)
'96 855 Turbo
K&N, H&R, Mobile 1
Its a wagon thing...
You wouldn't understand.
bugsbunnies95_850t
Year and Model: 99 v70R
Post by bugsbunnies95_850t »
Well i took the jump. thanks to the fantastic guys on this forum i found a t5r ecu and soon will be pluggin the bad larry into my 850 turbo.. ill keep u all updated on how well or bad it turns out ... keep your hopes high for me!
code-man850
Just to follow up (7 months later) everything worked out great. I did the stage zero before and everything was happy. A great safe mod.
'96 855 Turbo
K&N, H&R, Mobile 1
