wiper pump not working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bhapper
Post by bhapper »
1990 740,wiper pump just stoped ,is their a relay for it,the wipers do work,Brad
1986 760 wagon181g(dead)auto
1990 740 sedan 240g auto
1990 740 sedan 86g auto
1988 760 wagon 90g auto (mint)
1994 850 sedan 140g stic
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Understand the washer pump?
There is no relay for this as it does not draw enough current to warrant it.
Can you hear the pump when you activate the switch? If 'Yes' then check the jets to see if they are blocked. If 'No' check to see if you have 12 volts at the pump which sits on top of the reservoir. If you have 12 volts then you probably need a new pump - obtainable at FCPGroton. Sometimes a sharp knock to the pump will kick it into life but this will only be a teporary solution. If no power to the pump check the earth (ground) lead for good connection.
As the wipers are working it is not the fuse because they use the same one.
Of course, the first question should have been, "Is there water in the reservoir?" but you have probably checked that. :)
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
bhapper
Post by bhapper »
yes h2o in res,no sound,will check voltage,tap ,,the other 90 740 has a good pump(no becomming a parts car)Brad
