Greetings all.
This is a 1996 Volvo 850 that won't return to idle once the accelerator is depressed. I've cleaned the throttle body and made sure the plate is unobstructed and moving freely.
The throttle wheel moves freely to open throttle, but does not close when foot off pedal. I can manually roll the wheel closed without much effort.
So, a real novice question: Is there some sort of throttle return spring or coil that might have failed and left the car? If so and someone thinks that might be the problem, a photo or diagram of same would be appreciated.
Throttle won't return to idle
Saratoga850
- Year and Model:
1996 850 GLT, 1990 240 DL wagon
- Has thanked: 17 times
- Been thanked: 35 times
The throttle cable spindle wheel has a spring in it...I suspect that is bad. You can try silicone spray on that wheel but if the spring is bad, your problems will persist. Do you have a junk yard near you? All of these are the same from '93 through '98 70 series Volvo's.
Saratoga850
- Year and Model:
That's a very helpful suggestion MiJ. I'll give it a shot. Thanks, and still open to any other suggestions.
- Year and Model: Many Volvos
- Been thanked: 76 times
Check and clean the IAC valve and its lines as well.
- 2270 Views
Last post by Paul_okie
- 357 Views
- 2183 Views
Last post by malcolm2
- 3488 Views
Last post by ShadowDancer
- 1078 Views
Last post by kcodyjr
