S70 water pump torque specs
Finally purchased all parts at the local Volvo dealer (got 15% discount) to replace TB on my S70 1998. I also bought a new water pump. Found torque specs for mech. tensioner (20Nm) and idler pulley (24Nm), but cannot find specs for the water pump. Can someone tell me the torque specs for the water pump? Thank you much in advance.
- Year and Model: Many Volvos
- Been thanked: 76 times
15 lb/ft - I don't have my cheat sheet handy to convert that to Newton Meters.
DO NOT torque the water pump bolts to 15 Foot Pounds, this equals 180 inch pounds and WILL snap off the bolts. I did it after reading your post, thanks for that. Lucky for me it didn't strip out the aluminum threads first. The correct torque is 17 NM or 150 inch pounds.
- Has thanked: 1613 times
- Been thanked: 4078 times
Old post resurrection warning...
On my 1999 the correct torque is
Water Pump To Block 17 Nm (13 ft lb)
If your bolts snapped, it was not the extra 2 ft lbs, the bolts were already dead.
- Has thanked: 312 times
- Been thanked: 818 times
That!abscate wrote: 28 Jun 2017, 11:36 ... If your bolts snapped, it was not the extra 2 ft lbs, the bolts were already dead.
- 3605 Views
Last post by gibbi42
- 1520 Views
Last post by 2forty
- 4467 Views
Last post by ktuuri
- 7555 Views
Last post by miticavolvo
- 3255 Views
Last post by draser
