Key won't come out of ignition lock
This topic is in the MVS Volvo Repair Database » Performance Whiteblock Parts for Sale - Turbo, Manifold, Block & More
SteveT
Post by SteveT »
Hi all,
The key won't go to the 0 position in my '98 S70, it goes to I, II and III (it starts and runs OK) but it stops about 1/8" before 0 and will go no further. Has anybody ever experienced this problem and, if so, what is the solution? Thanks. Steve
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1252 times
Post by matthew1 »
Turn the steering wheel left and right. The steering lock sometimes interferes with the ignition.
Also -> Amazon link
Guest
Post by Guest »
Thanks, it acutally turned out that someone had depressed the shift lock release switch when I was driving and when it's depressed apparently some kind of solenoid is activated that doesn't allow the key to be removed. When I pulled the switch back out with a pair of pliers the key came out.
matthew1
Site Admin
Post by matthew1 »
*Thanks* for getting back to us, that's good to know.
Also -> Amazon link
