1991 740 Turbo Brakes
Is there something special about bleeding the brakes on my 1991 740 Turbo Wagon? My mechanic says that he can't get them to bleed out.
Does your car have ABS (anti-lock brake system)? There is a very specific bleeding process for Volvo's without ABS as theye use a unique dual triangular brake circuit. If your car does have ABS then again there is a procedure because it can be difficult to ourge the air from the ABS acumilators. Al lthe correct bleeding procedures are in the manual.
