Metal to Metal
Icecold
Metal to Metal
Post by Icecold »
My 850 T5, model 1995 is giving me a hard time. Since I purchased the car in 2000 it has always produced a
Smash
Post by Smash »
I can't imagine what it's like to live up there - I was there for 3 months only. Are you in Rek?
Smash
Post by Smash »
And oh, sorry, if you are doing the work yourself, I'd start with the brakes as they are easier to work with. However, yes some 'going bad' CV joints will make noise, but it's more 'rythmic' than just a continuous grinding - you may be OK with just swapping pads.
You can also swap right/left rotors and see if the noise changes.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1250 times
Post by matthew1 »
It could be the inner, plastic fender rubbing on the wheel. The plastic nuts can pop off, leaving the fender to sag onto the wheel. It happened to me because in tight turns the wheel was striking the fender and moving it, which stressed and popped the nuts.
Your English is very good. I would not have known it wasn't your first language.
Also -> Amazon link
maybevolvo
Post by maybevolvo »
Try lifting the front of the car and spining the wheel manualy in neutral... (choke the wheels and put the handbrake on ) Equip yourself with a recorder that has input/output and a good mic and headphones, now keep the wheel spining while you put the mic in different places and listen on your headphones. Another good It could be the bearing in the front hub. Im by no means a volvo expert I dont even have a volvo ( not yet anyway ) but this worked for me while trying to fix a few other cars i own.
Regards,
Tom
Icecold
Post by Icecold »
Hi guys
I just wanted to let you know that my problem is solved. I turned to an experienced mechanic who came to the conclusion that the wheel bearing was at fault. The bearing was changed and the irritating sound has wanished. At a cost of around 500 $ but well worth it I think.
I just wanted to thank you for your comments in trying to help me solve this problem.
