04 V70 Transmisison Flush
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
2004 Volvo V70 2.4l n/a, automatic. I'm getting ready to flush the transmission fluid. I have 16qts on the Toyota T-IV fluid on hand. I've used the 2qt pump out, put in, on older RWD Volvos and this is what I want to do here.
Is the upper or lower line on these cars the return line? What size is the tubing that will fit into the radiator/cooler, or does this one pump from the line. Thanks in advance
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Here ya go...read it through and you'll be good to go (make sure you follow info for the P2 cars and not the 850 or first gen x70's): https://www.matthewsvolvosite.com/forums ... f=1&t=8767
otis44
Post by otis44 »
Thanks
