S60 2003 Wheel noise.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
BremX
Year and Model: 2003 S60
Post by BremX »
I recently bought a 2003 S60 D5. While driving between 50 and 60 Mph there is a humming noise coming from the front passenger side wheel. However if i go above 60 the noise becomes quieter again. Also if i brake from over 65 there is some vibration in the steering wheel. Any suggestions on if it is one problem or many? Thanks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1253 times
Post by matthew1 »
Welcome to MVS.
Warped rotors, wheel bearing, imbalanced wheel, or combination of all.
Always work from simple/inexpensive to complex/expensive, so in that vein, have the wheels balanced and report back.
Without more info, that's about the best I can recommend. If you can inspect the front passenger wheel, inside and out, you might find a wheel weight coming off.
Good news is that none of those three culprits are serious or expensive, especially if you do it yourself.
Also -> Amazon link
