XC70 2001 Rear axle oil check
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
musie66
Year and Model: V70XC 2001
Post by musie66 »
After reading of numerous problems with bevel gear failure on these cars I checked mine and it seems okay, just needs a little top up. Having got the car up I guessed I should check the rear differential. I can see what looks like a filler plug on the left side high up on the diff casing. Is that where the oil level should be and what grade of oil should be used in this and the bevel gear?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
If JRL doesn't check in, you might want to ask this question (or better yet, do a search) on www.xc70.com If I remember correctly, it's best to pump the oil out of either of these differentials and then add new oil...also what each one takes is different so make sure and get the correct fluid in there.
