s70 1999 Newbie General question
I recently purchased a 1999 s70 and i have been having problems with its drivability.Its seem like the car does not have enough power.I have to press very hard to get to 50mph,also when i barke, the car acts like it want to die..look like the fuel or something, not sure.I recently went for an oil change and found out that my timing belt was almost broken and i had to replace that right away which was a lot of money.I would like to know the possible reason to see if it something i can fix by myself.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Could be bad timing.
When they replaced your timing belt,it's very possible that they didn't done it well!
Did you had these symptoms before timing belt replacement?
Was there missing teeth on the old timing belt?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
How many miles on your car? Is it a turbo? Who "fixed" the timing belt? Is the "check engine light" on? What grade of gasoline do your use, 87-89-92?lilah321 wrote:I recently purchased a 1999 s70 and i have been having problems with its drivability.Its seem like the car does not have enough power.I have to press very hard to get to 50mph,also when i barke, the car acts like it want to die..look like the fuel or something, not sure.I recently went for an oil change and found out that my timing belt was almost broken and i had to replace that right away which was a lot of money.I would like to know the possible reason to see if it something i can fix by myself.
Klaus
- misha
Is your check engine light on?If it is,read the codes and post'em.Otherwise it's just guessing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I have about 134,000miles on the car, the check light engine came on one once and later went off so i was not able to read the codes.I had the timing belt done volvo certified mechanic.The car stalls every time i get to stop light or brake but has never actually,looks like somthing that has to do with the fuel but not sure.
Klausc
Fuel air ratio is determined by a number of factors. You may have a vacuum leak, the air hose that goes from the air cleaner to the throttle might be loose, your plugs may need replacement, and you might have a clogged fuel filter.
Klaus
JRL
- Year and Model: Several
- Been thanked: 16 times
Possible ETM problem
895meztz94
- Year and Model:
Definite ETM problem.
1999 Volvo V70 2.4 Base 207k miles and counting
2003 Saab 9-5 Linear
- 892 Views
Last post by dcarlson12
- 1159 Views
Last post by kahl
- 4257 Views
Last post by 93Regina
- 1965 Views
Last post by amblerman
- 965 Views
