S80 Cabin Filter
John Cherubini Dublin
- Year and Model:
S80 Cabin Filter
Hey lads,i've got an S80 2000 2.0T to replace my 96 850 but steaming up inside on normal air flow when a/c not selected?? I got a new cabin filter but dont know where it goes. Is cabin filter and pollen filter the same thing? Any help greatly appreciated thanks
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Not quite, a pollen filter filters outside air only. The cabin filter your S80 has filters all air. Is this car RHD? If so, remove the soundproofing panel from the driver's side and the filter is located in bottom of the air conditioning unit. I've attached some notes on both operations.John Cherubini Dublin wrote:Hey lads,i've got an S80 2000 2.0T to replace my 96 850 but steaming up inside on normal air flow when a/c not selected?? I got a new cabin filter but dont know where it goes. Is cabin filter and pollen filter the same thing? Any help greatly appreciated thanks
S80 Air Cleaner.pdf- (92.36 KiB) Downloaded 349 times
S80 Soundproofing.pdf- (77.22 KiB) Downloaded 365 times
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
- Year and Model:
Thanks alot VCA,Job done in 5mins thanks to your response and diagram,it is RHD yes and found it under the passenger side.
cheers,
John
cheers,
John
- 921 Views
Last post by polskamafia mjl
- 1864 Views
Last post by stephansvolvo
