Who makes the OEM Spark Plugs?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
soundquest
Year and Model: v70 2005
Post by soundquest »
the VOLVO Dealership in Seattle wants $60 for a box of 5 spark plugs for my 2000 VOLVO V70 T5 (non AWD). I need to know who makes the OE plug for this car (Bosch?, NGK?) . And second, I need to know the part number of a plug that is copper and pre gapped to the right specs that will go right in this car. Appreciate your help on this in advance. Also, what is the oil capacity for this car with oil filter replacement? Thanks. Also, anyone know a place online that sells the plugs for cheap?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
If it's like the 850/V70 up to 2000, they are Champion, gapped at .028 inch.
https://www.matthewsvolvosite.com/search ... &sa=Search that might help. MIJ will know when he sees this thread.
Any of the three sponsors (top of the page) will have these, (probably at far) less than $60.
Also -> Amazon link
VCA
Been thanked: 5 times
Post by VCA »
matthew1 wrote:If it's like the 850/V70 up to 2000, they are Champion, gapped at .028 inch.
Turbo cars have Bosch as the OEM I believe--the latest pack I picked up for my 99 S70 turbo were "Made in Germany" and had the markings I'd expect to see on a Bosch plug.
2008 S80 T6 AWD
1999 S70 GLT
soundquest
After researching, I believe you are correct and more specifically that they plug is the Bosch FR7DC or 7555 (replaced by the 7955 which is copper and iridium but you can still ge the 7555 if you look hard enough). I am going for copper here and not platinum, otherwise it would be FR7DP. If anyone thinks I have been given the wrong information please feel free to correct. Otherwise, thanks.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
I think it's BOSCH,but i always buy genuine VOLVO with 3 pipes.It's a set of 5 spark plugs.I change them about 70-100k km.Last time i replaced spark plugs after 75k km,and they wasn't worn much.
But that's for genuine VOLVO.I believe that for NGK,CHAMPION...etc,replacing interval is about 20-30k km.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I agree- the OEM is probably made by Bosch...I say this because of the markings and "made in Germany" on them- same as another poster. That said, the Bosch copper work great on either non-turbo or turbo cars. On the turbo you'll just have to change them more often, but so what- they are typically less than $2 apiece.
soundquest
I went with the copper, specifically the Bosch 9755 super plus copper version. $3 a pop at Napa. Here they are on Amazon:
https://www.amazon.com/gp/product/B000PKX7W8
I was assured by the tech that these were pre gapped to fit the V70. Can anyone confirm this? I have a 2000 V70 T5 2WD. Thanks.
Assured or not assured (in writing or by word) I still check the gap on every plug- it helps in preventing problems down the road and having to take the plugs out and doing it somewhere where you might least prepared to do it.
soundquest
MadeInJapan wrote:Assured or not assured (in writing or by word) I still check the gap on every plug- it helps in preventing problems down the road and having to take the plugs out and doing it somewhere where you might least prepared to do it.
and to make sure, what is the exact gap supposed to be?
On the P2 models ('01 and newer) Volvo actually says 0.03 inches for gap on turbo and 0.028 on non-turbo but I go with 0.028- I feel the car runs better. If you are boosting more than stock on your turbo, go down a bit more, maybe to 0.026.
