2001 S80 2.9L non-turbo
I'm trying to replace my rear struts. The lower support bolts are very hard to remove. On one side I finally got the bolt loose but it only speads the steel flanges apart as I continue to unscrew it. If I continue one of these flanges will break off. So I stopped.
I've been using PB Blaster for the last four days to try to loosen it up. No luck.
On the other side the bolt still doesn't budge.
My local shop states that the bolt should be torched off.
Any suggestions on methods or tools to get this job done?
S80 Rear Shocks/Strut replacement
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
- Has thanked: 17 times
- Been thanked: 35 times
These instructions from VADIS might help you:
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
According to my VADIS, you don't need to do all that if you're just changing the shock absorbers. You jack up the car and install a spring retainer (tool 9997079), then lower the car, remove the nut from the top of the shock and the bolt from the bottom and withdraw the shock. Reverse to install the new shock.MadeInJapan wrote:These instructions from VADIS might help you:
These cars don't have a "strut" at the back, so I'm wondering if the OP is referring to a different car.
537playing
My issue is with the lower bolt. I'm not looking to replace the spring.
The lower bolt is rusted and unable to remove.
My question is how to remove this bolt, not how to remove the shock...
Thanks
Thanks
But you are replacing the shock...right?537playing wrote:My question is how to remove this bolt, not how to remove the shock...
Thanks
In regards to the bolt, I think you're in for an impact wrench- trying to imagine how you'd break something down there if you keep going. You might try heat-...like a torch...get it very very hot and then try untorquing it.
i'm glad i stubled upon this. i need to replace the rear shocks in my '01 s80. from just looking at the set up on the car it seems pretty straight forward.
the "special tool" 999 7079 i'm guessing is just to retain the spring so it won't go flying when you remove the shock? i'd assume there is another way to accomplish this with out having to get a volvo made tool.
It seems that way- I would say just about anything you could rig up there would work.
- 23 Replies
- 5453 Views
- 1990 Views
Last post by ThommyKent
