Check Engine Light - I need further advice
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
larrycrilley
Year and Model: v70xc 2001
Post by larrycrilley »
2001 v70xc turbo
I originally posted a few weeks ago I had a CEL and went to
Autozone the codes codes were P1171 and P0303. P1171 is for the MAF sensor and P0303 is a misfire on the #3 cylander.
Pulled the MAF sensor cleaned it with CRC MAF Cleaner, changed all 5 spark plugs, and the coil on the # 3 cylander. I cleared the codes and the car does still had a slight shake. Drove it a while and the CEL came back on. The check showed # 3 was still misfire.
According to the owners manual
Distributor ignition system
Firing order: 1-2-4-5-3
This tells me the #3 is on the right looking at the engine. I checked the coil on the left but no change.
Anyone have any futher advice.
Thanks.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Firing order is as you stated. However, the order from left to right (timing belt side to driver's side) is 1-2-3-4-5. #3 is right in the middle.
larrycrilley
With 20 years in the mechanical field I should have realized the firing order from the cylander order. Duh.
I work for the electric company; its amazing the lights ever come on. LOL
I am too happy to be embarrassed right now.
Thank you so much!
No problem- I hope this helps you solve your problem.
larrycrilley
Thank you so much!
The car now runs great and I am back to tearing up the roads of Long Island.
You are my new hero!!!!
