Recently my 2001 V70 odometer has stopped displaying. there is just the blank display under the speedometer and the cruise control has stopped working also. other than a brake light out messsage there are no outstanding messages indicating any other failure.
any ideas how to fix this?
thanks.
2001 V70 odometer problem
Bittertruth
- Year and Model: 96 850/ 01 V70
- Has thanked: 2864 times
- Been thanked: 1332 times
Sounds like a fuse.
I would suspect a bulb for the odo. Fix the brake light, & check the switch on the pedal for proper adjustment.
You can pull the cluster & swap the odo bulb with the clock to confirm, just make sure you disconnect the battery first, or you'll be paying the dealer to turn off the airbag warning light.
Bittertruth
Thanks, this sounds like a good fix!bshinn wrote:I would suspect a bulb for the odo. Fix the brake light, & check the switch on the pedal for proper adjustment.
Pretty sure this will fix it, but check this link B4 you start, no BS about the batttery, it can really cause problems if you ignore the procedure.
http://www.freewebs.com/howardsvolvos/e ... ronics.htm
GL, Bob
GL, Bob
- 2022 Views
Last post by Ozark Lee
- 649 Views
- 1103 Views
Last post by rspi
- 1581 Views
Last post by Matty Moo
- 1054 Views
Last post by mouseskowitz
