The alternater belt broke 18 months ago. I parked the car and drove my other. Repaired belt, tank was almost empty when parked, added 5 gallons of fresh gas. turns over but won't start. I don't know what to do next. advice please!
Patrick
1990 740 turbo won't start
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
My guess is the old gas has turned bad. You should drain it all out and add fresh with some fuel injector cleaner. I'm not sure how to drain the fuel lines/rail to get all the old gas out. Is there a Schraeder fitting on the fuel rail you can use?
Any time you store a car that long you should add Stabil to the gas.
I was having problems with not getting enough fuel to my injectors so I cleaned out as much as possible by unhooking the fuel line spraying in close to a full can of throttle body cleaner, let it sit for a bout 10 minuets, reattach the fuel line and started up the car. It took a few times to start but it never ran better.
- 3622 Views
Last post by lummert
- 2116 Views
- 1162 Views
Last post by 5ft24
- 1569 Views
Last post by 1966novacoupe
- 1549 Views
Last post by June
