cranks but won't start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
GOODTIMES
Year and Model: 1989
Post by GOODTIMES »
Hi everybody, I hope someone can help me with this. I have a 1989 740 Volvo that will not start. I have replaced the fuel filter,fuel pump, the fuel regulator & injectors were cleand/checkd good. spark plugs, and wires are good. engine cranks good, but will not start. (sounds like its out of gas) The only way i can get this engine started is if i disconnect the connectors above the first two injectors. The engine starts right up, but kinda shacky. I then reconnect the injectors, and the engine runs, and sounds great. I can drive it with no problems. I can turn engine off & on with no problems. BUT if the car is off for about 20 minutes, it will not start. I then have to disconnect injectors again.
What is the problem???
I got the fuel injection codes@ (socket #2) 113
ignition codes @ ( socket #6) =none 111
I hope this helps diagnose my problem. Thank You
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
1-1-3 is either injectors or fuel pressure. Have you checked the pressure?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
