Hi All,
When driving my S60 D5turbo recently I have been noticing a pulsing feel to the power delivery. Yesterday on the way home from work, this has got worse, and red warning triangle came on on the dash. My friend read the OBD code, "P0244" which says generic turbo/sup wastgate solenoid A range/performance.
When this is happening, very dark smoke comes from the exhaust, any clues?
Thanks
Keith
S60 D5 SE 2002 ERROR CODE P0244
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
You might have a failing Turbo Control Valve. IPD has an aftermarket replacement: http://www.ipdusa.com/Volvo-S60/Engine/ ... -395-4235/
Very dark smoke indicates an extremely rich condition.
vegasjetskier
I don't know, but if you ask at this forum Lucky can probably tell you: http://forums.swedespeed.com/zeroforum?id=52keithn wrote:sounds pheasable, thannks.
Is there anyway I can test if this valve is operating correctly, or is it a case of replace and try??
Ta,
Keith
- 1427 Views
Last post by CDoore54
- 1554 Views
Last post by beachmedic78
