Water Drip
Beano408
Water Drip
I have a 98 S70 w/82K & I have water leaking under the car - thought it was air cond run off but seems to be dripping more than usual (just had a new turbo installed with new return lines about 3K miles ago) When they changed the turbo they did not have any Volvo AntiFreeze & I believe they just used regular water to fill up the reserve tank as it just seems to be water in there - would you recommend me to have a flush & is so what Anti Freeze should I replace with? Also the other day I was low on coolant & had to add a cup of water to reserve tank so there must be a leak someplace? Any thoughts what to look for & could this be an easy inexpensive fix?
