S80 Filter Cleaning.
mugabenp
Year and Model: Volvo S80 2002
Post by mugabenp »
I have just cleaned my air filter with ( Gas or Petrol). It was really dirty. I could see that from the debris. I got it dried and reinstalled it and my S80 won't start. I am getting an message on the dash "Engine performance reduced". Any way round this or have I damaged some sensor.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
I hope you are talking about a K&N type filter and not a stock paper filter - you don't clean those, just replace them.
mugabenp
Post by mugabenp »
I have the attached type of filter. I think it might be K & N. How does K&N filter look like.
What could be the reason for the vehicle not starting?
vegasjetskier
The K&N should look reddish-purple and you should have a sticker on or around the airbox telling you it has a K&N in it. Here's a link:
http://www.knfilters.com/search/product ... od=33-2152
I suspect you do not have a K&N. I would go to the nearest auto parts store and buy a standard paper replacement filter, install it and see if the car will start then.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
If it doesn't start after the new filter, is it possible the fumes may have harmed the Mass Airflow Sensor?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I would say that the gas fumes definitely could have done something to the MAF sensor- it would be worth cleaning it...remember that gasoline is slimy and leaves a residue.. OEM, 3rd party or K&N- I've never heard of cleaning any air filter with gasoline. The K&N comes with a special kit that dissolves the grime and then you wash it with water before re-oiling it.
mugabenp
Post by mugabenp »
You are right. I think volvo is quite sensitive. I have cleaned filters this way before. For other models . such as Honda & Toyota, this is no problem. Let me see what happens when I clean the MAF sensor.
