XC70 towing an S70
I'm relocating to TX from WA and need to know if there's any foreseeable problem with my 2004 XC70 towing my husband's 98 S70. This move was planned to a "T" and now everything is falling apart. Don't want my car to do the same. Right now I have the towing receptacle without the hitch yet. Thanks for any help and advise you can provide.
LynnS
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Your XC70 is rated to tow 1650 lbs; 3300 lbs if you have trailer brakes and a 2" ball; your husband's S70 weighs 3150 empty, so you're OK there, but you would need brakes. You might be able to tow it on a dolly with brakes, but that would add weight and probably put you over the limit. Also, you'll need to have wiring put on both cars if it's not already there so you can light up the taillights and turn signals on the S70 (or you can get a set of magnetic towing lights to put on the S70 just for that trip, but you'll still need wiring for the XC). U-Haul has a wide assortment of hitches and tow bars available and might be able to outfit your car, or there is probably a hitch shop near you that can fab up a custom rig. If the S70 is a manual and you're towing 4 wheels down, remember to shift to neutral, release the parking brake, and unlock the steering column with the key and leave the key in there for the trip - lock the car with the key in the ignition and use the spare key to unlock it when you arrive or need to drive it. Good luck with your move.
vegasjetskier
Lynn,
I just wanted to add that if your husband's S70 is an automatic you may want to use a dolly for it. There are a lot of cars with automatics that can't be towed with 4 wheels on the ground (4-down) because the fluid pump is not running and it will burn up the transmission. If it is an automatic, you could check with your local Volvo dealer to see if it is OK to tow 4-down.
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
You can't tow any car with an Aisin AW5 series gearbox (Volvo 850, S/V70, S60, Infiniti I30/I35, etc.) 4-down. The pump is driven by the engine only, and since it won't be running, it will cook the bearings. You'd need a lube pump & disconnects (if you go this route, make sure the manufacturer specifically states it will work with your gearbox).vegasjetskier wrote:Lynn,
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
- 1635 Views
Last post by Rattnalle
- 24 Replies
- 3274 Views
- 1359 Views
Last post by ewbradshaw
- 4168 Views
Last post by 93Regina
- 3287 Views
Last post by bmdubya1198
