Hello every one. I just Bought my self a Volvo 2000, s80. is clean title. it got 140k on it.
and my check engine light is on, ABS and , exclamation mark ligh. I never had Volvo s b4. and my codes are P1633, P0010, P0011. So if anyone knows what to do? what might be wrong. if you could help me. that would be great !!! =)
Thank You
2000 S80 Check engine light on
- Has thanked: 17 times
- Been thanked: 35 times
Welcome to MVS.
The P0010 and 11 have to do with the camshaft reset valve.
Was the timing belt changed recently? If so, the variable timing and related parts might not have been dealt with appropriately- I would take it back and inquire. It is no easy task to get this right and will take special cam holding tools. Other than this, the P1633 is a faulty speed signal and may be related to your ABS unit. If I recall correctly, like the later model 850's and early (pre '02) x70 models, your ABS control module has a big failure rate but can be rebuilt for about $150 including you taking it off, shipping it to the rebuilder and getting it back. You might also be able to open it and resolder the bad joint yourself if you're savvy with a soldering iron.
