Like the title says. Has anyone ever tried to rebuild a starter?
I have a Bosch dealer near me if I need parts.
Danny
1989 240DL - Is it possible to rebuild a Bosch starter?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Anything is possible - if you can get the parts. Check with your Bosch dealer to see if he can supply what is needed. Bear in mind that if you are looking at replacing more than the brushes and springs it may be cheaper to buy a reconditioned unit which will have a warranty.
Yes, I have the instructions if you need them.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
The instructions are for a typical Bosch starter motor (Volvo's words, not mine). I have done several rebuilds on various makes of car with Bosch motors and they all follow the same pattern.
Bill.
Bill.
Previously:
Previously:
I'm so retarded...I'm not trying to rebuild a starter I'm trying to rebuild an alternator!
Would you happen to have instructions to rebuild alternators?
Thanks for the starter info, I'll save them for a rainy day!
Danny
Danny
- billofdurham
Back to the question "Is it possible......?"
Yes.
Bill.
Yes.
Bill.
Previously:
Previously:
Here's a price breakdown I got from Bosch.....
The part numbers you will need are as follows:
1 120 905 004 – which supersedes to a 1 120 905 533 000 - factory Deep-Groove Ball Bearing $ 13.66 each
1 120 905 026 – which supersedes to a 1 120 905 102 - factory Deep-Groove Ball Bearing $ 14.48 each
1 127 320 712 – Germany has stock on this item Rectifier $149.06 each
1 197 311 022 – which supersedes to a 1 197 311 028 – factory EL Field Rheostat $ 29.52 each
0 290 800 036 – factory Suppression Capacitor $ 11.68 each
1 127 011 020 – factory Parts Set Rotor $ 10.35 each
1 127 011 070 – Spain – 6 month lead-time Parts Set Clamp, B+, D+ $ 23.14 each
1 127 014 022 – factory Carbon-Brush Set $ 5.08 each
The individual diodes are not sold separately. You would need to purchase the whole rectifier.
The whole alternator part number 0 120 469 786 is an inactive part with Bosch.
It does cross to a Bosch Reman number of a AL157X which is available at the factory. Your cost would be $154.18 with a $75.00 core charge. We are a distributor for many other electrical lines as well. I have attached a copy of our line card for you. We can probably cross this to another vendor’s part number and provide you with a new alternator at a much lower cost than fixing your existing unit.
That sucks!!
Guess I'll be buying a new one!
Danny
That sucks!!
Danny
- billofdurham
FCP - $150.00 and no worries about what goes where.
Bill.
Bill.
Previously:
Previously:
- 2970 Views
Last post by Brickhaus66
- 1100 Views
Last post by rgk
- 3482 Views
Last post by reeltapegone
- 2629 Views
Last post by Mike Langlois
- 703 Views
Last post by mecheng
