'04 S60R stutters while driving
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
bubba_lug
Year and Model: '04 S60R
Post by bubba_lug »
i have an '04 S60R w/ 86,000 mi. It has recently startedted stuttering at highway speeds, it has even choked itself out.. i had the fuel filter changed, but the scanner showed that the fuel pressure sensor is bad. This was a recalled item for 03-04 models. They want $435 to replace it, but i have found the part for around $150. my question is 1) has anybody else had this problem? 2) where is this sensor located so i can change it myself? 3) and being that the car was bought overseas, would the vin show up on US recalls?
JDS60R
Been thanked: 3 times
Post by JDS60R »
If the car was registered in the US then it should be in the recall database. I attached the Volvo instructions for replaceing the fuel line and fuel tank pressure sensors.
Hope that helps,
J
2004 R tank pressure sensor replacement per Volvo.pdf
(37.23 KiB) Downloaded 359 times
2004 R fuel pressure sensor replacement per Volvo.pdf
(150.42 KiB) Downloaded 428 times
Volvo torque guide.pdf
(31.45 KiB) Downloaded 2885 times
Retired
OEMVolvoParts
Year and Model: ALL
Post by OEMVolvoParts »
The fuel pressure sensor is very common on that car. I'd bet you can change it in under ten minutes. We stock it and have free shipping if you mention MVS. Part number is 30756097!
bubba_lug
Post by bubba_lug »
it wasnt covered under the recall list, but i spoke with volvo and they are going to cost share the repair. thanks for the tips and repalcment insrtructions
