2004 V70 continously displays a "bulb failure, position light". This warning is a nuisence that has been around for 2 years. All lamps are working fine. I have removed the bulbs and reset them to ensure a good contact, with no results. I have been waiting for a "weak" bulb to burnout to end this problem message.
Any suggestions to clear this warning message once andfor all?
False Warning Message - "bulb failure, position light".
I have had the problem with the bulbs being slightly different from what the owners manual called for. I could not tell the difference in brightness but the wattage was different from side to side to trip the warning.
Glück.
Glück.
Macht's Gut!
What he is saying here could be the exact problem, they could be lite but not the correct bulb causing that problem.J5T wrote:I have had the problem with the bulbs being slightly different from what the owners manual called for. I could not tell the difference in brightness but the wattage was different from side to side to trip the warning.
Glück.
- 1339 Views
Last post by mal81394
- 5087 Views
Last post by JRL
- 2660 Views
Last post by firstv70volvo
- 4994 Views
Last post by Oly850
- 10523 Views
Last post by natural4reelz
