Fixed the last problem and now when I start it it blows lots of white exhaust. After awhile it starts blowing black exhaust with LOTS of carbon buildup. It is also getting really bad gas mileage like 12-14 miles per gallon. HELP!!!!
1990 240 white & black exhaust poor MPG
rainbowwillow63
- Year and Model: 1987 Volvo 240 DL
- Has thanked: 1 time
Here we go again-
Proud owner of
1993 Volvo 240 DL
1990 Volvo 240 DL-laid to rest
1987 Volvo 240 DL-sold
1989 Volvo 240 DL-sold
1993 Volvo 240 DL
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Do you have a check engine light this time?
Regardless of the CEL have you checked for fault codes using the On-Board Diagnostic (OBD) unit in the engine compartment?
Without seeing the car the symptoms you describe indicate the fuel/air ratio is too rich and you may be having problems with the heated oxygen sensor. However, check for fault codes before dashing out and buying one.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
rainbowwillow63
Nope, no CEL. Do I need to take it to a garage to have the codes read? I figured it would be gas/air ratio but I don't know anything about fixing that.
Proud owner of
1993 Volvo 240 DL
1993 Volvo 240 DL
- billofdurham
No, you can do it yourself with the attached instructions:Do I need to take it to a garage to have the codes read?
1989 and 1990 are the same. There may be no codes stored but it is worth checking, as it is free.
You now know something that a lot of non-Volvo garages don't - how to read fault codes on a Volvo 240.
Bill.
Previously:
Previously:
rainbowwillow63
I couldn't get the file to download-it says it is damaged and cannot be fixed
Proud owner of
1993 Volvo 240 DL
1993 Volvo 240 DL
- billofdurham
Now how did you break that?
I have downloaded it successfully but in case you are still having trouble go to 240 tests with codes and see if you can break that one.
Bill.
Bill.
Previously:
Previously:
rainbowwillow63
I guess I broke that one too
That's just how my luck has been going lately. I guess no fix for me
Proud owner of
1993 Volvo 240 DL
1993 Volvo 240 DL
rainbowwillow63
Hey Bill- I checked for codes
, there are none stored. Anything else I need to check?
It is still running rough but not stalling since I beat the cat. up.
Proud owner of
1993 Volvo 240 DL
1993 Volvo 240 DL
- billofdurham
No codes - back to basics.
Check throttle switch and connector.
Check ignition and sensor wires for good connections.
Check the earth (ground) connections on the intake manifold.
Check engine speed sensor.
Check for a leak on the intake manifold.
Check engine coolant temperature sensor (ECT). There are two of these, one for the temp gauge the other feeds info to the fuel control unit. You need to check the second one which you will find under the intake manifold for #3 cylinder. Hard to get at but does cause troubles with fuel consumption/running if it goes off.
Most of these items are on the forum if you do a search. Certainly the ECT is on, search with my name as author.
If you can't find any information on any of the above post back.
Bill.
Bill.
Previously:
Previously:
rainbowwillow63
Well, I finally figured out how to get the codes (duh, turn ignition on
Here are the codes I got:
Socket 2- 121, 113, 213
Socket 6- 111
I'm going to erase these and recheck after I drive again. Does it matter what order they are in? Again, I have no CEL.
I checked my oil today and it smells of gas??
Socket 6- 111
Proud owner of
1993 Volvo 240 DL
1993 Volvo 240 DL
- 938 Views
Last post by RaulGuichard
- 34 Replies
- 10013 Views
Last post by E Showell
- 3511 Views
Last post by oragex
- 1080 Views
- 2185 Views
Last post by Chock
