Done w/ 850 Looking To Move Up to S60...things to look for?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ANIGAV Inc.
Year and Model: 96 850 t5
Volvo Repair Database Done w/ 850 Looking To Move Up to S60...things to look for?
Post by ANIGAV Inc. »
Hello all,
After some deep thought and much pondering I've come to the conclusion that its time to let the 850 go. I'm shopping around for something around the 4-6k range and the s60 fits right into my price range.
The main reason for the change is that I'm trying to keep from spending money "suping" up a dd. I dropped a k in cosmetic upgrades for the 850 and its nowhere near where i want it to be. Basically, I'm at the point now that if i want to go fast i'll just buy a sports car.
I'm looking around for info but i figured the direct approach works too. So with that said... I'm looking to purchase an '01-'04 S60. Can anyone tell me anything particular to be on the look out for?
I hear the 01-02 trannies are junk and that the 01's have the ETM and its prone to problems.
How true is this and what else should i be looking for?
According to wiki there is a 2.4T and a 2.3T5..besides the horsepower is there any real difference?
1996 - 850 turbo
OEMVolvoParts
Year and Model: ALL
Post by OEMVolvoParts »
Yeah the early ones had transmission and ETM issues. The newer ones (02-), are good buys, they dont have any real issues. It will be better to spend a little extra money for one that is in good condition. If you can find one that had an extended warranty on it, that way you know it was taken care of.
rbodor3
Year and Model: 01 S60 LPT
Been thanked: 2 times
Post by rbodor3 »
T5 is a high pressure turbo, came with the 16T turbocharger and lower compression. This means that stock block can hold more power, it puts out more power, and comes with a bigger turbo. it also tends to be a bit harder to find and more expensive to buy, but of course that equates to better resale in these vehicles.
2.4t/2.5t are pretty much the same. Low pressure turbos, came with 13T turbocharger, high compression engines. This means more torque, but stock block cannot hold as much power, puts out less power than the HPT, and smaller turbo. Cheap and easy to find.
Don't even think about buying a naturally aspirated S60, they're useless.
Mechanical issues of the MY 01-04 volvos include the PCV system, ETM, transmission (b4 cover, valve body, software), lower front control arm bushings, upper engine mount, lower transmission mount, upper spring seats, and tire rub.
MY2002 S60 received only some of the fixes with the problems in the 2001, negligible IMHO. They also received upgraded rods and crankshaft.
Most solid S60s on the road now are the MY2005-2006 ones. Significantly more expensive, and harder to find.
01 Volvo S60 2.4T
igel513
Year and Model: 2003 S60 T5
Has thanked: 1 time
Post by igel513 »
What about d '03s. R there any issues w/ these mods
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
No more issues with the 03 than any other model excluding the 01-02. With the money you are talking about spending the issue is going to become finding a car that doesn't have a ton of miles. If you are buying one of these regardless if its an 03 model or an 09 model that has high miles (or any mileage) for that matter, be sure it has been serviced and maintained properly. These cars are fine automobiles when treated properly and not so fine when they are not.
