C70 Conv 1999 ABS computer
dkilborn
Year and Model: C70 conv, 1999
Post by dkilborn »
Had shocks and struts replaced. Three days later, ABS unit/computer is failing and ABS, Check Engine, Brake lights come on and speedometer and odometer stop/restart intermittantly. Could there be a correlation between the two issues or is it pure coincendence?
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
yes for the abs light because its on the front spindles and somthing could have happned when doing the struts. take it back to the place that did the work.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
rennspeed
Year and Model: 2000 V70
Post by rennspeed »
I just removed my ABS module, so I could replace it with what "I THOUGHT" was a good unit.
After reinstalling it...Not only do I have the ABS/Traction control light on, the BRAKE light is also illuminated.
As a nifty side effect the odometer, and speedo are now intermittent. (Sometimes they work, some times they don't)
What I do know is that when I push on the plug to the ABS module the speedo and Odometer start functioning again, and the BRAKE light vanishes.
I would push on the plug and see if that helps your problem.
Renn
