Got a quick basic question:
Where would I tap into to install a boost gauge?
Where to tap in to install a boost gauge?
find a spot on your boost line and place a t-fitting in it, then run the boost line through da firewall, then snake up along (neatly) the door/weatherstripping then run the electric from your gauge to your headlight controls- make sure to do some research for the s80 to get everything you need and also make sure you have a nice tight seal between the boost /vacuum line and the gauge with the crush washers that should compress and snug when you tighten up the supplied hardware to the gauge. Also please make sure to get a nice gauge that registers vacuum as well as boost or it's useless IMO
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
I hooked my boost sensor tubing to the vacuum tree above the throttle body, worked great and there were open ports for "expansion" left by Volvo, just pull off one of the caps and slide your tubing over snugly.
Regards,
- Jesse
Regards,
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
ojdorson
- Year and Model: 850R, 1996
- Been thanked: 3 times
I just looked up the IPD Gauge/Pod kit and there are PDF install directions right there. They're tapping into the line connected to the factory gauge and that way everything is kept in car. It seems smarter that way - any drawbacks to not going right off the intake manifold tree?
- Has thanked: 17 times
- Been thanked: 35 times
Don't think there's a tree on the S80- like one poster said, tap into one of the lines with a "T."
- 689 Views
Last post by cdscycleandatv
- 15 Replies
- 4199 Views
Last post by SlowLane
- 19 Replies
- 4843 Views
Last post by MrAl
- 599 Views
Last post by volvolugnut
- 674 Views
Last post by enotslim
