I bought the car with a beat tranny and replaced it recently. The car runs great now, but the orange arrow flashes almost constantly.
I brought it to the shop and they just told me it had something to do with the gears and it not being able to recognize that its fully in gear or something like that, Im not sure... He wasn't very clear.
The arrow does go away if we reset the computer, or sometimes on its own, but its never off for more than 10 miles. If it is off, it will mostly come back on when going over bumps, or on the highway...
So my real question is, how big of a problem is this?
How would i go about fixing this?
Will the winter mode still work (winters right around the corner)?
And should i even worry about it?
flashing arrow
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I would worry about it. This is a quote from the owner's manual:
Who actually fitted the box? Was it a general shop or a specialist gearbox shop? The flashing arrow is telling you something and you shouldn't just ignore it.
Bill.
You say:The lamp will light up when the Winter starting mode is engaged or if gears "3" or "L" are selected.
If the warning lamp begins to flash, this means that there is a fault in the automatic gearbox. Contact your Volvo dealer.
When you reset the computer how do you do it and do you check for fault codes before resetting it?The arrow does go away if we reset the computer, or sometimes on its own, but its never off for more than 10 miles.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- Year and Model: Many Volvos
- Been thanked: 76 times
Pull the codes from port A-1 and post them back. If you have never read the codes here is how it is done.
http://volvospeed.com/CheckEngine.php
The writeup is specific to reading codes from the ECU (Port A-2) but it works excatly the same when reading codes from the TCU (port A-1).
JRL
- Year and Model: Several
- Been thanked: 16 times
Damn right you should worry about it, you should not drive it as it is.
It's two things, the PNP switch is shot.
"ROW" the shifter back and forth about 20 times with the engine on and see if that helps, if so replace the switch
The only other thing is an internal shift fault in the tranny.
Was this rebuilt by you or did you buy a reman from Volvo?
If you continue to drive it with the flashing arrow, you WILL burn out the transmission, I will guarantee you this
yea I got the same problem on the flashing arrow too before, the code says Transmission slip, and the only way is to change the transmission.
I remember when the flashing arrow started when Im going up the hill.
try to change the trans oil 1st and see if helps.
the tranny was changed less than 3000 miles ago..
we bought the new tranny from a junkyard, actually. Its only got 60k on it. and other than the arrow, theres no issues.
I havent gotten a changed to read the codes yet
oh and when we reset the computer we did it by disconecting the computer for a few minutes
Kurai...try to check your tranny fluid 1st..compare your tranny fluid color with the fresh fluid that you have left...and 2nd try to smell it if it smell like burning..and 3rd try to rub your fluid between your fingers if its watery or not..let me know you result.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
You need to read the codes so we can find out what the transmission is telling you.
- 1278 Views
Last post by jose456891
- 957 Views
Last post by iruleyounow
- 13 Replies
- 2803 Views
Last post by jtmarks923
- 1346 Views
Last post by tyrendis
- 1246 Views
Last post by 95850turbowagon
