Last night I noticed that the remote will not lock the doors or activate the alarm. It will unlock all the doors however. If I try to lock the doors with the key it will only lock the drivers door. If I try to lock all the doors with the button on the door before I close it, it will lock all the doors only a few seconds later all the doors unlock again. Any ideas?
Also the seat belt chime is going off when the door is open.
Another thought, I do have my sons car seat installed with the seat belt. Could the tensioner be causing my problems? I may try unbuckling the seat but it is ridiculous to reinstall.
It does seem to be acting like a door is open, where would I check for door sensors?
***It turned out to be the in the ignition switch / column. Seems it was thinking the key was still inserted. I inserted and removed the key quickly a few times, heard the "click" when I removed the key and presto chimes stopped and all lock and alarms are functioning.
s80 2000 doors wont lock **UPDATE**SOLVED**
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Glad you got it fixed. Thanks for the update.
- 2459 Views
Last post by SuperHerman
- 3968 Views
Last post by thudson
- 1831 Views
Last post by dudeitssm
- 2070 Views
- 1872 Views
Last post by Faust
