Front Cigarette lighter not working,rear works on s60 2002
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
You might have better luck in the S60 section.markocars wrote:Anyone had this issue?
https://www.matthewsvolvosite.com/forums ... um.php?f=9
- Has thanked: 2866 times
- Been thanked: 1332 times
Moved to correct section. Markocars, you don't need to re-post.
Jagger
- Year and Model: 2005 XC70 T5 295'km
- Has thanked: 1 time
I have the very same problem on my 2001 V70 T5.
Ozark Lee wrote: "For the cigarette lighter check fuse number 30"
______________
Unfortunately I don't have any fuse with number 30 (in other words, there is no fuse holder with no.30).
Also check any legend for the fuses you can find.
______________
Ozark Lee: "They may refer to the cigarette lighter as an "Accessory" on the legend since a cigarette lighter is no longer politically correct."
______________
______________
You ever find an answer to this question? I have the same problem with my 2005 S60. I do not believe it can be the fuse, as, if I understand correctly, the rear and front sockets are on the same fuse. Neither of mine were working, and I replaced the fuse (it was located in the fuse box underneath the steering wheel, behind the first panel). The fuse was burnt, and replacing it brought the rear socket back up. But the front still does not work.
I think I have to replace the front. I removed the console trim to get close to the socket, but I have yet to figure out how to get the front socket out--to check the wiring and/or replace the socket. Anyone have tips? Can I pull or twist it out, or do I need to get into the rear of the console? Easy way to do that?
- 937 Views
Last post by Tabbrod
- 823 Views
Last post by swedet17
- 1797 Views
Last post by BEJinFbk
- 2589 Views
Last post by alschnertz
- 3228 Views
