Does anyone have a BSR Stage 3 on a S60 2.4T ??
paulcars60
- Year and Model: 2001 S60
BSR Tuning for a S60 2.4T as follow: Stage 1: PPC tune for the ECU. 252hp 302ft lb Stage 2: Cat back exhaust system with the same tune as Stage 1. 257hp 309ft lb Stage 3: PPC tune update for the ECU with a 3 inch down pipe plus race cat. 264hp 320ft lb Stage 4: PPC tune update for the ECU with new fuel injectors and a bigger turbo. 310hp 336ft lb Stage 4: IS FOR A MANUAL TRANS ONLY. Plus is must be done in Sweden.
rbodor3
- Year and Model: 01 S60 LPT
- Been thanked: 2 times
don't bother with either. Just do the Stage 1, and here's why:
- difference between stage 1 and stage 2 are only a $50 air filter, just buy a K&N and call it a day
- difference between stage 2 and stage 3 are a catback exhaust. Catback will give you the least amount of gains when it comes to an exhaust upgrade. First thing you want to upgrade on the exhaust side is the downpipe first, so just go to ipdusa.com, or eurosporttuning, or a custom exhaust shop and buy a 3" downpipe with high flow cat. Some day down the road purchase a 3" catback, but the downpipe is the most important gain by far.
-edit-
btw, you won't see 310bhp with their stage 3 kit. You'll probably see like 260bhp
-edit-
01 Volvo S60 2.4T
