Heater return tube
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
LA48340
Year and Model: 240 1988 & 1990
Heater return tube
Post by LA48340 »
Today I replaced the water pump on my 88 240. The new pump came with a gasket, an o-ring for the joint to the head and another small grommet gasket. The small grommet style ring I think is for the heater return hose compression joint. When I dis-assembled it, the end of the heater tube(metal) had a white plastic ring at the water pump joint end...thinking this was the seal I cut it off. It appears this ring is permanent and squeezes the grommet ring in the water pump cavity.
Does anyone know if this ring can be purchased as a service part. It leaks very badly without it.
thanks.
