Any suggestions as to why it won't fit...I cleaned the spline groves with a dremel tool whire brush... and added a touch of grease to the spline... fitted the wheel hub assembly to the spline and used the center mounting bolt to press the two parts together .....still no luck
Then I wire brushed the housing where the spline fits into from the back side....still no luck
Any suggestions will be greatly appreaciated
thanks
New wheel hub assembly will not fit onto the axle spline
