S80 2000 oil on spark plug #6
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
franrico
Year and Model: S80 2000
Post by franrico »
Hi I just changed the spark plugs on my car, and I finded oil on #6 plug
check engine ligth on before the service what can the problem be I ask.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
If it's on the top of the cylinder head, the oil could be leaking from the cam cover gasket or it could have been spilled. If it's not a lot, just wipe it off and reassemble everything.
If it's in the cylinder (showing on the electrode surfaces of the plug), the rings are probably shot or you have bad valve guide seals in that cylinder. Engine disassembly is required to fix those.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
Hello franrico, 1) Get the Haynes manual for your car. It's not the best resource but will help you alot. 2) Get a code reader and include codes in your posts. Everybody's in the dark if we don't know the Diagnostic Trouble Code(s). Note: Some auto parts stores offer to read your codes for free; many do not. Frequently, members say these stores will never hit the "clear" or "erase" button for you. That means you cannot determine any rate of recurrence of your problem. The bottom line there is; it's a sales gimmic. They want you to buy a code reader from them. Wherever you buy it, get one which is CAN compatable. Many which are on clearance sale are old ones which aren't. You can use it for years to come and you'll make friends all over the place. Happy New Year, Kira
