96 850 Alternator Removal & Replace
BGBROWN125
Year and Model: 96 850/ 92 240
Post by BGBROWN125 »
Is it me or is this a wicked task? I am having one heck of a time trying to remove the alternator for replacement.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I have not yet had to replace one on any of my 850s but I understand that there is a bolt or bolts that you need to get to through a hole in the pulley. I will need to fire up a Windows partition to get to VADIS but I will try to pull the procedure for you.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
BGBROWN125
Thanks Guys.... Ihave to finish removing it tomorrow so the middle daughter can get out of my vehicle! : :)
anmartin44
Year and Model: 1994 850 n/a
Has thanked: 2 times
Been thanked: 2 times
Post by anmartin44 »
Its not too bad, but make sure you remember what bolts where. i was at a wrecking yard when mine went out(lucky, i coasted in). found one with 100k on it for $15 and put it in in the middle of parking lot. I had never done it before so it took me about four hrs cause i had to feel for all the bolts and figure out the PS res detached. you have to take off the idler pulley and bracket that holds it. the alternator is really in the worst poss spot on this car.
good luck, man and Merry Christmas!
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
Pauloil
Post by Pauloil »
be sure to check out the starter cable
https://www.matthewsvolvosite.com/forums ... 7&p=109529
99 V70XC 158K
95 850glt 188K
BGBROWN125
Thanks for the assistance...I could not have done it without your help.
By the way.... [http://www.partsgeek.com/ has some really awsome prices on parts.
You guys ROCK.....Merry CHRISTmas
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
I did my first one on my 93 5speed 850 2 weeks ago. it took me about an hour and a half. you just need to have the right tools.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
newowner
Year and Model: V70,S70,850,C70 98
Post by newowner »
Help, I'm in the middle of changing the alternator and can't figure out how to get it out.
To bring you up to speed - I have read the write-up (VolvoSpeed) but still can not get it out, the write-up seems to be missing tiny details. I've gotten to the point where I'm trying to get the last bolt out but can not find it. Power steering pump is loose, tensioner is out, I can't figure out how to get bracket holding the idler pull out, which would allow me access the last bolt holding the alt. in (the closest to the block). So I'm looking at the idler pulley, AC compressor, and alternator. Where do I find the last bolt... Please any photos.
Please any assistance would be greatly appreciated, :oops: :!:
Trenchcoat
Year and Model: 850, 1996
Post by Trenchcoat »
It's impossible to see with the manifold in the way. Facing the engine bay from the front, you can feel down to the farthest part of the alternator away from you and you'll feel the head of the bolt. I had to use a straight wrench to turn that one, no room for a ratchet. If you still have trouble locating the bolt, just look at your new alternator to figure out spatially where that bottom hole is.
