my 460 GLE 18 i shuts down after one klm. i think its the fuel filter. where is that located and how do i change it ?
second my steering wheel makes a noise everytime i turn and started to feel heavy. can it be the hydraulic system ? everything started after i checked the safeties box and moved some safeties.
thanx in advance
steering wheel and fuel filter
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The fuel filter hangs from a bracket under the rear passenger side floor.
Release the fuel pressure before starting to replace the filter. The easiest way to do this is to pull the fuel pump fuse while the engine is running. The engine stops with no fuel pressure left in the pipe. When you see the filter you will see it is an easy job to replace it.
Bill.
Is this the fuse box?the safeties box
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
When you were working under the steering wheel did you accidentally move the plastic covers around the steering wheel? If the covers are touching the steering wheel this will tend to make it harder to turn and will make a noise as the wheel scrapes over the plastic.
Bill.
Bill.
Previously:
Previously:
- billofdurham
Is there enough fluid in the steering reservoir? Any sign of a fluid leak on the steering?
Bill.
Bill.
Previously:
Previously:
- 1208 Views
Last post by WillieEvans
- 20 Replies
- 13310 Views
Last post by oragex
- 1910 Views
Last post by Goldchemist
- 15 Replies
- 2917 Views
Last post by 454cid
- 11 Replies
- 1393 Views
Last post by Blacklab467
