2006 XC 70 oil pan bolt stripped threads
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ctracy
Year and Model: 2006 XC 70
Post by ctracy »
recently took my 06 XC for oil change to local Monroe shop- Mechanic pulled out threads( explained that steel bolt likely was over-tightened last change) when he removed bolt in oil pan- had some difficulty but ultimately able to retighten bolt with silicone. Thinks I may need new oil pan .
Any thoughts. Car has 42K mi. Thanks Charlie
JDS60R
Been thanked: 3 times
Post by JDS60R »
Hi Charlie,
Sorry to hear about your problems on such a new car. You can always take it back to the shop that overtightened it if you are sure it was them.
The pan is just a piece of metal and can be repaired. Oversized oil pan bolts are availalbe (do not use a self taping oversize plug as they are meant for steel and can fracture aluminum alloys) or a new thread can be expoxied in after the damage is removed. Just get with shop who understands what a Helicoil is and you will be fine. As always compare the repair costs with the replacement cost of a new or salvaged pan.
If you have high mileage it might be a good time to get the oil pan o rings replaced and have them put on a good used or new pan while it is off.
These are great too http://www.timesert.com/html/drainplug.html
Best of everything,
JD
Retired
JDS60R
Post by JDS60R »
For the most part I would suggest a timesert over a helicoil.
Retired
