940 Turbo 1992 Condensor collar
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
p0shr
Year and Model: 1992 940 Turbo
Post by p0shr »
The forward collar on the air conditioner condenser has turned gray. Is this a sign that the condenser is bad?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Welcome to matthew's Volvo Site.
I'm not sure which collar you are referring to. Can you post a picture?
If the AC is still working the condensor is good.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
p0shr
Post by p0shr »
The collar is the first one you see behind the pulley.
I removed the belt because I was told the condenser would shortly freeze up with use.
Will see if I can get a picture.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I think you are referring to The A/C compressor. The part behind the pulley is the clutch. Removing the belt was a good idea. If you want your A/C to work and the A/C clutch is bad you will need to replace the clutch.
1988 Volvo 760 Turbo Wagon
p0shr
Post by p0shr »
Herewith photo of condensor collar.
The gray ring  is the problem.
cattledog
Year and Model: 2000 V70R
Post by cattledog »
Compressor with pulley and compressor clutch assembly. That one is seized, I bet. Sure looks like it got really hot!
I think the clutch assembly is available seperately, otherwise replace the whole compressor and clutch assembly. Was the A/C working ok before all this?
p0shr
Post by p0shr »
Yes, she was working fine as far as I could tell. It was the mechanic who decided to remove the belt.
cattledog
Post by cattledog »
If you reach down there and try to turn that pulley, with the engine off of course, does anything rotate?
I'm guessing he took it off because there was alot of smoke , right?
p0shr
Post by p0shr »
I'll check but he didn't mention smoke.
Also, I try to turn it (with the engine off).
p0shr
Post by p0shr »
I reached down, grabbed the gray collar and turned it with my hand. It and the pulleys behind it turned easily but not loosely.
