Front suspension expertise
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Dave123
Year and Model: '03 S80, '98 S70 T5
Post by Dave123 »
I've got an '03 S80 with 54K miles that developed a clunking noise in the front suspension. Thanks to the forum, I replace the front sway bar links which appears to have solved the noise issue. During installation of the new links I happened to notice that one of my outer tie rods also made a clanking noise when rotated. Should there be any movement in the outer and inner tie rods? As always, thanks for your insights!
gunner
Year and Model: s80 t6 1999
Post by gunner »
No play is allowed , it directly effects toe setting on your alignment and shows as wear to inside edge of front tires , normally. Replace as required , reset alignment ... G
