centre high level brake light on
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
jerry blue v70
Year and Model: V70 t5 2001
Post by jerry blue v70 »
i have a 2001 v70 t5 on which the centre brake light has come on and will not go out even when you take the car keys out
at present i have unpluged the rear wiring loom which is next to the side brake lights to stop it draining the battery
any suggestions on what may be causing this fault ? jerry
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
Hello, Nobody has posted an answer yet so I'll try guessing. Since you'd think ALL the brake lights would light up if a brake light switch were bad or out of adjustment you'd be reasonable to think toward something else which controls lighting in these new-fangled horror machines we drive. What powers these lights? I've read that weak batteries in alarm units can create all sorts of problems. Are the center brake lights part of the alarm's light show? Did you install a trailer hitch wiring black box in the left rear of the car? Is there a seperate powered relay which lights the CHMSL? Anybody else? Kira
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
It might be 2 wires shorting (or a broken one) in the tailgate harness. The wires inside get worn out after the hatch is open & shut many times.
Someone has pictures here of what to check out:
https://www.matthewsvolvosite.com/forums ... 3&p=116394
'98 S70 T5
2016 Chevy Cruze Premier
jerry blue v70
Thanks for the reply i will have to get a meter on it does any body know a site to get wiring diagrams for v70 2001 volvos?
