1990 240 DL Charging issues
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bgerhartjr
Year and Model: 1990 240DL
Post by bgerhartjr »
I recently acquired a 1990 240DL that has a charging issue. The alternator was replaced and it still does not charge. I am in the process of acquiring replacement tail light components that appear damaged and not working as suggested in other posts. Does anyone have the wiring for this alternator? The info I found online is sketchy and does not show all of the wiring details, I want to make sure it is properly connected, I was told the terminals were broken when the belt broke. Any help would be appreciated.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The attached is a system wiring diagram. If you need the full diagram let me know.
240 charging circuit 1990.pdf
(57.67 KiB) Downloaded 140 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
bgerhartjr
Thanks for the reply, I found that one or one similar on the web. I have found 3 wires near that location that are not attached, I assume one is the exciter ? The red is obviously the link from the starter There is also an 18 ga black and an 8 or 10 ga green. I guess the answer would be yes, can you get me the full diagram
billofdurham
The full diagram is attached but I don't think it will help as all of the wires at the alternator are red. Black is usually earth (ground). Is your alternator sitting in rubber bushings? If it is it won't be earthed.
240 wiring engine compartment.pdf
(175.1 KiB) Downloaded 133 times
Bill.
Previously:
