Earlier today I just found out that I'm having a major cooleant leak. First clue was that the air comming out of the heater was not hot at all, although the heater control knob was turned all the way up. I pulled over and started looking around for the source of heater-problem, after about 10 or 15 min. I noticed the cooleant resevior was completely empty. Gently driving in to the nearest gas station and filled up with some fresh cooleant liquid. Let it idle and kept on filling until it stopped draining the resevior. Then gently drove the last couple of km home, and then checked again. All of the cooleant was drained from the resevior (with only a 20 min. drive). I've checked the radiator plug, the main hoses from the resevior to the radiator and the hose from the radiator to the engine. There seems to be no visible leaks around the hose joints - haven't checked under and back of the engine at this late hour - I'll check it tomorrow.
So does anyone have an idea where to begin looking?
440 1995 B18U - Troubleshooting cooleant leak
Skinkehunden
- Year and Model: Volvo S60 T5 2005
skinkehunden
Current: Volvo S60 T5 2005 150.000 km on the clock.
- Volvo Volvo S60 2.4 2006 with 204.201 km on the clock.
- Volvo 440 Pacific 1.8 1995 with 258.197 km on the clock.
- Volvo 440DL 1.8 1992 with 268.500 km on the clock.
- Ford Escort 1.3 1977 with 64.000 km on the clock.
Skinkehunden
After a lot of troubleshooting, I finally found the leak - it was the backside of the engine. It was a slow leak from a hose and was only leaking when the engine was hot. So I apparently ran the engine dry of cooleant(!!!), but luckily the engine seems to have taken no damage *pheew*. Replaced the hose with one from my spare '92 model, and no leaks anymore.
skinkehunden
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You were lucky that there was no damage. Thank you for the update.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 18 Replies
- 2944 Views
Last post by misha
- 9716 Views
Last post by zoli440
- 16136 Views
Last post by Medusalith
- 16334 Views
Last post by pastoralia
- 16926 Views
Last post by volvolugnut
