Disc-3 Error
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
joejoecat
Year and Model: 2001 C70 LT
Disc-3 Error
Post by joejoecat »
I have a 2001 C70 Vert with a SC-901 Radio with a 3 disc changer. All was will ,until I started to push some buttons trying to get to the next disc. The head of the changer with the cartridge ejected itself from the unit. It is sticking and won't go back in and I can't get the cartridge out of it . It reads "Disc-3 Error". Anyone ever encounter this problem? Any fixes ? Thanks
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
That's the same reason VCR's are a by-gone technology. I was watching some old movies the other night, and the stupid thing at the tape and got it stuck.
At this point, I would remove the radio from the dash (there are 2 tabs - one on each side of the radio) - push those in with your key and they'll pop out and enable you to pull the thing out. Then, unplug it from the back and take off the top shell, and see if you can figure out what's jammed up on it. It may just need some gentle pressure on the mechanism and it will come un-stuck.
Make sure you've got your radio code :wink:
'98 S70 T5
2016 Chevy Cruze Premier
