Strange noise after new OEM converter installed
99 S70 AWD I'm not sure how to explain this, but..... I had a new catalytic converter installed two weeks ago. Now, when I come to stop, the car runs smooth, then there is a gradual increase in a strange, loud noise (like a bad muffler) and the car runs a little rough. The noise gets progressively louder the longer you sit with the car in drive. However, if I put the car in neutral, it idles smooth and when I accelerate from the stop, the noise goes away. When I come to a stop it happens all over, again. The car runs fine otherwise, no CEL's, great gas mileage. Any Ideas or suggestions will be greatly appreciated.
- Year and Model: Many Volvos
- Been thanked: 76 times
It could be that the rubber mounts that suspend the rest of the system got strained during the cat / down-pipe replacement process and the muffler or tail pipe is touching something. If you can observe the problem in your drive way you can use some heavy gloves to move the rear portion of the exhaust system around to narrow the problem area down. The exhaust system grows as it heats up and things that seem clear when cold can actually rattle once things heat up.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Grab the heat shield & try to shake it around. I had a muffler replaced once, and it rattled something awful every time I decelerated, turned out they didn't tighten down the heat shield.
'98 S70 T5
2016 Chevy Cruze Premier
Thanks for the advice. I'm taking it back to the shop that installed the cat, today. When I called him yesterday, the first thing he said was he thought the motor mounts might be bad. However, I didn't have this problem before the new cat was installed. I'll post back later whn I find out something.
- 4922 Views
Last post by MadeInJapan
- 600 Views
Last post by FCPEURO
- 797 Views
- 463 Views
Last post by FireFox31
- 568 Views
Last post by jonesg
