Brake lights on S60 t5 2001
My third light works but not the rear brake lights, All fuses are fine and have changed all the bulbs. Anyone with any ideas. Thanks
I'm not familiar with the model but check the harnesses where they enter into the lens housing and where they plug into the main harness of the electrical loom. Having a helper look at the lights, shake and gently twist the connections and see if that helps.
Regardless of outcome, Plug-unplug them and spray with a plastic safe solvent. After that blow out well, air dry for a bit (10 minutes) and put them in again.
You'll have to remove some carpet to get at it. Good luck.
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
