I have a 2003 s40 with almost 107K and I believe that Volvo specs 108K as the time to change the timing belt. My question is, are these interference engines where the engine will seize if I don't change it? I'm debating ($$) whether to wait till it dies (if that doesn't make a difference) vs. changing it now.
I have a starter question I'll also throw up separately. This place rules!!
Timing belt change- schedule?
casualcoma
- Year and Model: 2003 s40
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
It is an interference engine and you will need a major rebuild if the belt snaps. The scheduled change is at 105,000 so you are over the top now.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Bill is right, do it now!
I'm at 95k / 10 years old now and did mine yesterday. It was dried and cracking. It is not just wear you have to worry about but age as well. They do dry-rot and that leads to internal degridation. Its a bit of a pain, yes, but I would rather do it when it's due rather than realizing you'll have to replace it anyhow when you are bolting a new head on...
I wouldn't run a T-belt over 90k. 60k is usually going to be a safe bet. The technology in the belts is getting better, but until they are proven good for 250k miles, it really isn't bad to have to do it a couple times over the life of the car.
No matter how you look at it, the day or so of personal time or the $500 to get it done are always better than the time and money you would be out of doing a rebuild.
And the issue is a bent or broken valve. You might have to replace a piston if it's severly damaged by hitting a valve, which is likely, worse case is it snaps a valve off. That will require that cylinder (whole engine rebuild at this point) be bored. I have heard of a piston being split which cracked the block (here, it will certainly seize). A new engine isn't cheap and used ones have their own set of concerns to ponder. Not trying to scare you, just letting ya know it's a critical item to stay on top of.
Just my $.02.
Mark
Just my $.02.
Mark
